Activity Forums Adobe After Effects Expressions Refer to JSON data by index AND attribute name
  • Refer to JSON data by index AND attribute name
    Posted by Jon Smith on August 20, 2019 at 6:36 pm
    Hey all, I’m trying to work with JSON data and referring to the data by both index and attribute name. I tried a couple different methods but I’m not able to get it to work. I’m guessing it’s a syntax thing but I’m not sure. Any help is appreciated!
    Example JSON:
    “item1”: {
    “name”: “Item 1 Name”,
    “parameter”: “Item 1 parameter”,
    “item2”: {
    “name”: “Item 2 Name”,
    “parameter”: “Item 2 parameter”,
    “item3”: {
    “name”: “Item 3 Name”,
    “parameter”: “Item 3 parameter”,
    expression method #1
    myData = eval(footage(“sample.json”).sourceData);
    myData.item1.name; // works
    myData[0].name; //doesn’t work
    expression method #2
    footage(“sample.json”).dataValue([0, 0]); //works
    footage(“sample.json”).dataValue([0, name]); //doesn’t work
    Tomas Bumbulevičius replied 7 years, 1 month ago 2 Members · 2 Replies
