Activity › Forums › Adobe After Effects Expressions › Refer to a value outside of the comp
  • Refer to a value outside of the comp
    Posted by Jerome Laville on April 29, 2020 at 1:23 pm
    I have 256 compositions, all very similar and with the same black solid as the top layer. On that solid I have a basic expression that toggles the opacity on and off randomly, off being 10 times more likely than on.
    If I wanted to change the likelihood from 10 to 20, I’d have to go and change the expression in all 256 compositions. Could I avoid that by setting that X number somewhere in my project outside of these compositions, and refer to it? I could then easily play with that number and affect all compositions.
    Many thanks.
    Jerome Laville replied 6 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 29, 2020 at 2:10 pm
    Sure. It might look something like this:
    pct = comp(“Controls”).layer(“Controls”).effect(“Percent”)(“Slider”);
    seedRandom(index,true);
    random() < pct/100? 100 : 0
    Dan
  • Jerome Laville
    April 29, 2020 at 2:14 pm
    That would be it. Thank you so much for this and for everything you do Dan.
