  • Posted by Alex Harding on February 1, 2007 at 4:51 pm
    hi there
    is it possible to reference the rotation value of a layer without taking into account the ‘multiplier’ value?
    ie
    my rotation (its self governed by an expression) resolves its self to ” -3 x 0.0 ”
    however, another expression which is dependent on this value reaching 0, reads this as -1080
    is there a way to only reference the rotation out of 360, rather than than the accumulating value?
    cheers,
    Alex
    Mike Clasby replied 19 years, 7 months ago 2 Members · 1 Reply
  • Mike Clasby
    February 1, 2007 at 7:00 pm
    It would be nice to see the expression you’re working on, but methinks you need to use “%” the modulus operator, it gives the remainder.
    In this expression, a Blue Solid’s rotation is the same as the Medium Red Solid’s rotation (just by pickwhipping the Blue Solid’s rotation to the Medium Red Solid’s rotation.
    thisComp.layer(“Medium Red Solid 1”).rotation
    So “-3 x 0.0” on the Red gives “-3 x 0.0” on the Blue.
    But if you add %360 to the expression you get what you are after:
    thisComp.layer(“Medium Red Solid 1”).rotation%360
    The 360 tells it what to divide by, and then gives the remainder.
    So “-3 x 0.0” on the Red gives “0 x 0.0) on the Blue.
