Activity › Forums › RE:Vision Effects › ReelSmart Vector Blur: Foreground objects not blurring correctly
  • ReelSmart Vector Blur: Foreground objects not blurring correctly
    Posted by Jeff Adams on July 29, 2011 at 1:00 pm
    Hi I’ve had the Reelsmart Vectors 3 plugin for awhile, but decided to try to put it into my workflow recently. For the most part its nice, but I’ve noticed that foreground objects will end up with a hard edge. From what I can tell its because each pixel determines its own blur and doesn’t look around to see if any pixels should be blurred on top of it. Is it possible this problem is fixed in v4?
    Pierre Jasmin replied 15 years, 2 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    July 29, 2011 at 5:38 pm
    Alpha information in the MV image is also important to properly handle edges. As per your description this might be your problem.
    https://help.revisionfx.com/task/21/#/tutorial-87
    You can always send a sequence of like 3 successive frames + their motion vectors to techsupport @ revisionfx.com
    Pierre
