Activity Forums DaVinci Resolve Reels as Project o Timeline? (Limited Powergrades amount)
  • Reels as Project o Timeline? (Limited Powergrades amount)
    Posted by Guillem Ventura on October 21, 2011 at 4:37 pm
    I’m grading a 3D feature.
    DCI requires working with 15-minute reels.
    I have shots repeated in different reels, I’d like to re-use the grades:
    My plan was storing Powergrades for all the shots so I can port them from one project to the other.
    Every reel is a different Project.
    I’ve aparently exceeded the amount of available stills to store as Powergrades.
    I save them but when closing the project and opening the next reel’s they’re gone.
    It handles up to a certin number, then forgets down to last time saved within its stills capacity.
    I may have the reels as different Timelines within the same project, but then the project would become 5 times heavier…
    An I use the timelines to have different Left and Right versions, if I mix different reels…
    This is the only solution I see, any better thoughts?
    How do you guys work the reels, as projects or timelines?
    Thanks a lot!!
    -Guillem @ Blur Producciones, Madrid.
    Guillem Ventura replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
