Activity › Forums › Avid Media Composer › Redundant Avid media
Posted by Scott Davis on April 24, 2017 at 11:57 pmI have an Avid MediaFiles folder that might contain a lot of duplicates (media was copied over at the Finder level). Is there a way to find out what is duplicate and get rid of it?
Eric Santiago replied 9 years, 4 months ago 4 Members · 4 Replies -
Pat Horridge
April 25, 2017 at 6:23 amMDV is the app you need.
Pat Horridge
Broadcast & Post Consultant, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
pat@vet.co.uk -
Eric Santiago
April 27, 2017 at 12:12 pmThanks, Pat I was looking for something other than MediaMover.
Glenn Sakatch
April 27, 2017 at 2:02 pmWell, if they are truly redundant you can simply copy the the media to the same mxf numbered folder, and not have explorer overwrite anything. Any files left in the original spot would be duplicates.
Manually, you could drag the database from each folder to a bin and see what is there.
Glenn
Eric Santiago
April 28, 2017 at 5:41 pm[Glenn Sakatch] “Well, if they are truly redundant you can simply copy the the media to the same mxf numbered folder, and not have explorer overwrite anything. Any files left in the original spot would be duplicates.
“An old practice that’s bit me in the but in the past.
Ill give the freeware app a try.
