Activity Forums Adobe Audition Reducing wind noise
  • Reducing wind noise
    Posted by Pjoconnell on August 4, 2005 at 4:39 pm
    I have an outdoor wedding that has some minor-to-medium wind noise intermittently on the track. Is there a way of reducing that interference, at least somewhat? I’ve tried Noise Reduction, but the profiles I’ve tried apparently arent accurate enough.
    THNX/PJO
    Willie Toth replied 21 years, 1 month ago 2 Members · 1 Reply
  • Willie Toth
    August 4, 2005 at 7:30 pm
    You will need to bring the clip into the EDIT side of the program and highlight JUST THE NOISE you would like to remove … Once you do that go to EFFECTS > NOISE REDUCTION > NOISE REDUCTION > CAPTURE NOISE PROFILE … Once you capture the profile highlight the whole clip go to EFFECTS > NOISE REDUCTION > NOISE REDUCTION … Here is where you MUST take care not to remove too much of the noise at once … I like to remove it by about 62% or less and if I need more I reduce the percentage … When you preview and it sounds like people are talking in a rain barrel you are going too far … WILLIE
