Activity Forums Adobe After Effects Reducing scale of photoshop files causes pixelation?
  • Reducing scale of photoshop files causes pixelation?
    Posted by Tom Lee on November 27, 2011 at 11:04 pm
    Hi Guys.
    I have been working on some book covers sent to me from cover designers. When I use the photoshop files in after effects in a comp the same resolution as the original psd document i have no problem. but If i want to make a comp significantly smaller and reduce the size of psd layers such as text or simple graphics. The layers become extemely pixelated and are unusable. I would expect this when trying to enlarge a layer beyond its intended resolution but not when reducing it.
    Any ideas? when in photoshop you can reduce a layer to any size and it still remains the same quality, but in after effects it goes very pixelated for me.
    Thanks in advance
    Tom
    Erik Waluska replied 14 years, 9 months ago 3 Members · 3 Replies
  • Erik Waluska
    November 28, 2011 at 12:24 am
    No, you should not have pixelation when reducing the scale. Check that your comp preview window size (magnification ratio) is set to 100% and your quality to full. Also, be sure that the layers themselves have their quality switches (diagonal line icon) set to full.
  • Chris Wright
    November 28, 2011 at 10:50 am
    collapse transformation/continuously rasterize switch(looks like a sun) should keep vectors crisp. Now if they’re not vectors, well then its up to a good bicubic resize plugin.
  • Erik Waluska
    November 28, 2011 at 3:53 pm
    He is working with PSD files, not vector, so the layers will come in as raster, which is fine for scaling down without a plug-in. FYI – You can convert those layers to live text layers in AE if you wanted to scale them up or change the text. Layer>convert to editable text
