Activity › Forums › Adobe After Effects › Reduce Project feature
Posted by Shahed Naderi on May 4, 2014 at 11:18 pmhello
I have a bit complicated project , when I want to reduce it to a comp it dont remove other comps . I think It’s because of common shared solids and adjustment layers .
I want to know if there is a fast way to make those elements unique to their compShahed Naderi replied 12 years, 4 months ago 3 Members · 13 Replies -
George Goodman
May 5, 2014 at 1:56 pmThis will remove anything that is unused in your project:
https://aescripts.com/project-cleaner/
One way to make it more effective is to go in and replace any nulls or solids that are the same with just a single one. For example, if you only ever use 1 null per comp, just replace all the nulls with “null 1” and then run the script.
“|_ (°_0) _|”
Sincerely,
George
http://www.vimeo.com/georgegoodman
http://www.linkedin.com/in/georgefranklingoodman -
Shahed Naderi
May 5, 2014 at 3:07 pmthank you George, actually that was what I done, but it didnt reduced it to those comp which I want to hold on to, I give this script a try ,
thank you ,
would you take a look at my other post under the name of glass effect ?
I posted it last night also.thank you Sincerely
-shahed
Walter Soyka
May 5, 2014 at 3:18 pm[Shahed Naderi] “I have a bit complicated project , when I want to reduce it to a comp it dont remove other comps . I think It’s because of common shared solids and adjustment layers . I want to know if there is a fast way to make those elements unique to their comp”
To confirm — you are selecting the comp you want to keep (and only the comp you want to keep), then using File > Dependencies > Reduce Project (or File > Reduce Project, depending on your version).
A shared asset in a comp will not stop Reduce Project from removing that comp. Are you sure that the main comp is NOT dependent on those other comps somehow? If any of those comps appear as layers in the main comp (even if they are guide layers or invisible), Ae will consider them dependencies and will not remove them during Reduce Projects.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Shahed Naderi
May 5, 2014 at 3:55 pmyes I’m sure those comps which I wanted to be removed they dont share anything in common with my main comp , I even replaced all solids and adjustment layers with new ones , but the option didnt work .
but I’m sure I’m doing something wrong.
thank you Walter Soyka -
Shahed Naderi
May 5, 2014 at 4:06 pmWalter would you be kind enough to look at this post ?
https://forums.creativecow.net/readpost/2/1050862 -
Walter Soyka
May 5, 2014 at 4:08 pm[Shahed Naderi] “yes I’m sure those comps which I wanted to be removed they dont share anything in common with my main comp , I even replaced all solids and adjustment layers with new ones , but the option didnt work . “
I think you misunderstand me. It doesn’t matter to “Reduce Project” if the comps reference the same assets.
For example:
COMP A
— Asset 1
— Asset 2COMP B
— Asset 1
— Asset 3If you select COMP A and do a Reduce Project, it will delete COMP B even though they share Asset 1. It will not delete Asset 1 or Asset 2 since they is necessary for COMP A. It will delete Asset 3 since that is not used in COMP A.
Now consider this:
COMP A
— Asset 1
— COMP BCOMP B
— Asset 2
— Asset 3If you select COMP A and use Reduce Project, it will not delete COMP B, nor Asset 2 nor Asset 3. It looks into COMP A, sees that COMP B is necessary to render COMP A, and it sees that Assets 2 and 3 are necessary to render COMP B and thus COMP A, and leaves them all intact.
Are the comps you are trying to remove from your project actually used somewhere in the comp you’re trying to keep? If they are, they cannot be removed by Reduce Project.
Walter Soyka
Walter Soyka
May 5, 2014 at 4:12 pm[Shahed Naderi] “Walter would you be kind enough to look at this post ? https://forums.creativecow.net/readpost/2/1050862“
I’ll try to check later it this afternoon. I’m in the middle of some work and renders at the moment.
Walter Soyka
Shahed Naderi
May 5, 2014 at 4:23 pmyes , I got it , and no , they dont share anything in common , just solids maybe, I need to look closer
thank you
Shahed Naderi
May 5, 2014 at 9:51 pmI think I found the answer , all the comps that I wanted to get rid of share the same expression , they refer to main comp, is it right ?
Walter Soyka
May 5, 2014 at 10:04 pm[Shahed Naderi] “I think I found the answer , all the comps that I wanted to get rid of share the same expression , they refer to main comp, is it right ?”
Nope. It doesn’t matter what’s in the comps you want to delete — and Reduce Projects does not evaluate expressions to see if they’re necessary even for dependencies, so if something is ONLY referenced by expression from the comp you keep, it will blow them away and break your expressions.
If the comp you want to keep requires other comps, it will not delete them.
Please confirm these are true:
You are selecting the comp(s) you want to keep in the project panel and nothing else, then using File > Dependencies > Reduce Project.
The comp you want to keep does not contain the comps you want to delete at all — neither directly, nor in nested precomps.
Walter Soyka
