Activity Forums Adobe After Effects Reduce Chatter – Key Cleaner
  • Reduce Chatter – Key Cleaner
    Posted by Filip Stillerska on May 5, 2018 at 7:23 pm
    I always check this box, even if I don’t see any noticeable chatter, just to make sure.
    Is there ever a reason or time when you shouldn’t use “Reduce Chatter” in Key Cleaner? Why is it defaulted to unchecked?
    Steve Bentley replied 8 years, 4 months ago 3 Members · 2 Replies
  • Roei Tzoref
    May 6, 2018 at 6:06 am
    one obvious reason not to use it is that it’s memory intensive. You could use the free plugin fx console to customize the default parameters of this effect for later use.
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
  • Steve Bentley
    May 7, 2018 at 5:30 pm
    It also softens the key so in effect removes information that could be useful for things like fine hair.
    Every key is different (even from the same shoot) so to do film quality keys you need to consider each shot on its own.
