Activity Forums Apple Final Cut Pro Legacy REDONE gives me scary 3k jitters in my 2k project.
  • REDONE gives me scary 3k jitters in my 2k project.
    Posted by Josh Hamilton on January 22, 2010 at 8:47 pm
    I’m new to the red workflow, but I’ve seem to run across my first snag. I’m ingesting red media as instructed by the whitepages to prores 4444 at 2k in a 23.98 rate. Then i came across a slate stating there was a change to 3k @ 50fps, which fcp, as ive read and now discovered does not like at all.
    Now from what I’ve gathered from other posts is I should compress with compressor this back to 2k, 2048×1152. Would this in its self solve my dilemma? I’ve tested a couple clips and seems ok, am I in for any surprises when my clients come in?
    Ben Holmes replied 16 years, 7 months ago 3 Members · 3 Replies
  • Josh Hamilton
    January 22, 2010 at 8:56 pm
    Before any cranky cows scold me for not referring to the RED Camera forum, I’m perusing that right now. Sorry in advance for jumping the posting gun….
  • David Bogie
    January 22, 2010 at 10:30 pm
    RED scares the bejeebers out of me, I am fortunate that I will never need to know anything else than how to look up an experienced RED shooter.
    Please come back and tell us how you solved yor issie and good luck.
    bogiesan
  • Ben Holmes
    January 23, 2010 at 6:13 pm
    You would do better right now to use REDCine with a full debayer, or REDRushes to transcode footage if you want to relink later – Apple’s software does not currently support the improved colour science in recent RED footage, and you will lose colour fidelity and quality in the blacks. You will also be able to do the resizing and conform there. Unfortunately, the Apple Whitepaper does not reflect the current, fast changing world of RED tech.
    I recommend a look at recent posts on the RED forum about this.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
