Activity Forums Apple Final Cut Pro Legacy redirect RAM
  • Posted by Jason Spencer on July 14, 2009 at 12:48 pm
    I am working on an indie feature on an iMac G5 on FCP 6.0.6.
    First and foremost, the iMac only has 1.5GB of RAM… I understand that FCP needs at least 2GB to run smooth, but we have the computer loaned to us via the prod company, so we can’t upgrade the RAM, we need another solution. Is it possible to redirect/allocate more RAM to FCP? Any other clever solutions? I’d love to hear them!
    Thanks.
    Andrew Piggott replied 17 years ago 8 Members · 11 Replies
  • 11 Replies
  • John Roberts
    July 14, 2009 at 1:50 pm
    Might seem like a silly post but make sure to quit out of everything when you’re working in FCP with that low amount of RAM. I would make sure to not even launch something like Dashboard or close out all “widgets” just in case. Don’t even have Safari or iTunes open when you’re editing to help with this problem. Close out of literally everything except FCP.
    I’m not really sure about RAM allocation, but if you only have FCP open then you will only be allocating to FCP.
  • Jerry Hofmann
    July 14, 2009 at 2:15 pm
    You can assign up to about 2.7 gigs of RAM to FCP, but it certainly has to actually be there… so the answer to your question about not adding it and get the benefit of it is no.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Ernie Santella
    July 14, 2009 at 2:25 pm
    Jerry,
    How do you ‘force’ assign RAM to FCP?
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
  • Ariane Fisher
    July 14, 2009 at 2:33 pm
    I wouldn’t try to use any motion templates with that set up. I’ve edited in FCP on that same hardware without too much of the spinning beach ball of death, even with 15 layers of video with blend modes, etc. It’s possible, just stay completely away from motion templates; they won’t work well there. If you need to round trip to motion, here’s what worked for me. Place the motion project in the timeline. Edit in motion, then export the .mov at the same res as your sequence and replace it in the timeline. Best of luck with it; plan on plenty of time for coffee during render. 🙂
  • Steve Eisen
    July 14, 2009 at 2:50 pm
    System settings/memory & Cache drag slider for Application.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Ernie Santella
    July 14, 2009 at 3:03 pm
    Where do you find this adjustment? I can’t find it.
    Ernie Santella
  • Jason Spencer
    July 14, 2009 at 3:17 pm
    These are all very helpful postings! Thanks. Steve, I’m also finding it hard to locate the memory & cache settings. Is it in System Preferences?
    -J
  • Victor Perez
    July 14, 2009 at 3:22 pm
    I don’t remember seeing a slider on older Macs, but was that actually a PC thing?
    Victor
  • Steve Eisen
    July 14, 2009 at 7:43 pm
    Final Cut Pro/System Settings/Memory & Cache (Shift Q)
    Steve Eisen
    Board of Directors
  • Ernie Santella
    July 14, 2009 at 7:51 pm
    Thanks Steve. I already knew about those settings in FCP, I was looking for some menu on the basic mac system settings for memory allocation to different programs. (There’s no setings for that)
    Ernie Santella
