Redigitizing multiclips
All right, I’ve looked around and found lots of people who think there is nothing wrong with the multiclip editing, and others who think it’s al broken. Here’s what happened to me.
I did an offline edit at DV resolution from beta masters. It was a one camera shoot of a performance, so I made a timeline with all the different takes, cut off the “ends” so that all tracks are the same length, make a subclip of each track, then I made the subclips multiclips. Everything works fine through the offline, but then every-time I try to use media manager to create the offline to hi-res, I get a dialog box that says “general error can not link (clip name) to multiclip”, and in the new project the multiclips stay online. O.K. I thought I’ll just re-digitize the multiclips in the new project, well first it digitized way way too much footage that where not in the multiclips, then I got the same error, only this time FC deleted some of the original DV footage from the hardrive and took the multiclips offline. After trying a second time to redig them (by doing the individual clips) some of them became 1 frame clips in the timeline and that one frame that was left wasn’t even the right one.
I’ve had this problem with several different projects lately on three different systems, So I guess I’m wondering if anyone has re-digitized a project using media manager with multiclips successfully or not?
