Activity › Forums › Adobe After Effects › Red Type in After Effects
  • Red Type in After Effects
    Posted by Josue Martinez on May 7, 2009 at 3:09 am
    Has anyone had a problem using small red type in After Effects. When I play back the rendered movie in quick time, the red type seems to look choppy. When I use small white type the text seems to be smooth. I’ve tried different reds, to see if that helps. Does anybody have a solution to this, or has anybody ran into this problem.
    Josh Martinez
    Creative Manager
    Chris Wright replied 17 years, 5 months ago 2 Members · 1 Reply
  • Chris Wright
    May 7, 2009 at 3:46 am
    understandable if you render out DV 4:1:1. 4 blocks of chroma get deleted per re-render. Welcome to needing uncompressed.
    btw this is why you don’t use sharp reds and sharp greens next to each other in sd-tv.
