Activity Forums Avid Media Composer Red transcoded with audio
  • Red transcoded with audio
    Posted by Gwen Sputore on May 31, 2010 at 7:34 am
    Hi there, I’m in the process of syncing with ‘Time of Day’ .wav and MXF, which have been transcoded from Red Rocket. I have found that the sound track is coming across (with nothing in it as we deselected audio in Rocket) so when I autosync it makes a merged clip (with 4 audio tracks) rather than a subclip. I’ve only transcoded a few, and was wondering if anyone knew how to bring a vision only MXF out of Red Rocket so I can sync quickly.
    Hope you can help……..
    zingarra
    Gwen Sputore replied 16 years, 3 months ago 2 Members · 2 Replies
  • Job Ter burg
    June 1, 2010 at 7:31 am
    I’m guessing that somewhere in the Red application, you’ve either added an audio track, or you have created an ALE with events that have audio.
    In mC5, it’s going to be a breeze, since you can then simply ignore the audio that comes with the video.
    In earlier versions, there is a workaround.
    – Unlink your imported picture clips (it’s something like holding Shift and Command while clicking the Clip menu, and Relink becomes Unlink)
    – Modify them so that they are V-only (Clip->Modify->SetTracks)
    – Relink the clips (Clip menu, don’t hold Shift and Command).
    The result will be V-only clips, making AutoSync possible, rather than Grouping.
  • Gwen Sputore
    June 1, 2010 at 11:22 pm
    Thanks for that.
    zingarra
