Activity Forums DaVinci Resolve RED Time Code Options
  • RED Time Code Options
    Posted by Robert Due on November 3, 2011 at 3:58 pm
    Is there a way to have Resolve read both time code sources on RED files? Or at least offer the ability to choose?
    Sometimes I get edls pointing at edgecode TC and Resolve is wanting to look at the other type (I forget what it is called time of day?).
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
    Vivek Vedagiri replied 14 years, 10 months ago 3 Members · 3 Replies
  • Andrew Shtern
    November 3, 2011 at 5:16 pm
    In the Config/Source tab you can choose Camera, Absolute or Edge Code.
    Andrew Shtern
    Editor/Colorist
    The Coffeepost @Kiev, UA
  • Robert Due
    November 3, 2011 at 5:18 pm
    Thanks. I should have known that one.
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
  • Vivek Vedagiri
    November 3, 2011 at 5:36 pm
    Hi Robert,
    On the Config page, there is a Source tab. On that you can select which timecode you want to use for your RED clips. There are 3 options – Camera, Absolute. Edge. When in Camera mode, it uses whichever of Absolute and Edge was chosen as default on the camera.
    Note that this needs to be set before browsing to/adding the RED media into the media pool. If you are looking at RED media in the media browser when you change the time code setting, you should refresh the folder for the media to be displayed with the new setting before proceeding to add it to the media pool.
    Vivek Vedagiri
    Blackmagic Design
