Activity › Forums › Apple Final Cut Pro Legacy › Red text / graphics look messy when I watch on TV!
Posted by Daniel Haythorn on October 13, 2007 at 7:02 pmHi everyone,
My problem is this: I am editing a film which contains some instances of red text / graphics on a dark background. When I export and watch the film on DVD on my TV, the text and graphics look really ugly, with strobing diagonal lines and general ‘interference’. Is there any way I can change this?
Many thanks in advance!
Dan H.
Thomas Imbrigiotta replied 18 years, 10 months ago 4 Members · 11 Replies -
Teach
October 14, 2007 at 6:39 amHi, have you tried different background colors, like gray? and if you have, do you get the same bleeding? What program are you building your titles in?
Daniel Haythorn
October 14, 2007 at 10:26 amThanks for that…
Is the best way to do that to use the Desaturate filter, or the HSV adjust?
To be honest in both cases it hasn’t seemed to fix it…
Daniel Haythorn
October 14, 2007 at 12:43 pmI haven’t tried a different colour, but there’s a certain issue with branding (the client wants their colours) so it kind of needs to be blue.
In one instance the graphic has been created in Photoshop and then imported, and in other instances I’m building the graphic using the title tool in FCP. In all cases I’m getting that wierd strobing lines I talked about.
Thankyou!
Teach
October 14, 2007 at 7:20 pmThe program you should be using is LIVE TYPE. All i know is i work with LIVE TYPE all day long and it works perfectly with FCP and i get no bleeding whatsoever.
Teach
October 15, 2007 at 2:35 pmlet me know how it goes for you, if you need help how to use it, i can explain certain things to you. Unless you already know how to use it. The outline is the best part of live type in my opinion and the way the colors are just tight on the television. The clarity is perfect. You can put shadows behind and you can change the size of the point of the outline of the letters. You can do everything in live type. When you fix a title in live type, it automatically gets fixed in your timeline in final cut pro.
Daniel Haythorn
October 15, 2007 at 6:33 pmThanks teach,
To be honest the deadline for the project I posted about this has passed and in the end I didn’t have a chance to look into Livetype properly (the deadline was a tight one!) so I’m not 100% satisfied that I did fix the fuzzy red graphics … I’ll definitely be looking into Livetype for future projects. I am intriuged that it links to the FCP timeline… that would certainly make life a lot easier, and anything’s got to beat the FCP title tool which is clunky at best.
I’ll no doubt have some queries along the way, so thanks for your offer of support!
Dan.
