Activity Forums Apple Final Cut Pro Legacy Red text from powerpoint displays awful
  • Red text from powerpoint displays awful
    Posted by Mike Procyk on March 13, 2008 at 2:55 pm
    I’m laying powerpoint slides over a video, and the text that is red
    looks terrible. It looks bad in FCP, but when exported (I export
    a non-self contained movie, with the stock settings) it is
    unreadable. The other graphics look anywhere between perfect
    to just OK.
    I’m working in a DV timeline, the slides are sized to 720×480
    before being imported in FCP. I also did the range check and
    the red is not over.
    Mark Raudonis replied 18 years, 6 months ago 4 Members · 6 Replies
  • Shane Ross
    March 13, 2008 at 2:58 pm
    Red in video has always been troublesome…especially in text graphics. Always best to avoid red in text when you can help it. Or make it less bright…dark red is better than bright red.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Mike Procyk
    March 13, 2008 at 3:01 pm
    Even if it’s not out of range?
    I agree, I’d avoid red text (it’s not my powepoint!)
    We’re actually going through it and changing the
    color.
  • Mark Raudonis
    March 13, 2008 at 3:07 pm
    [Mike Procyk] “Even if it’s not out of range? “
    Yes!
    Red is the highest frequency color in the spectrum, and therefore is the hardest to reproduce.
    https://www.usbyte.com/common/approximate_wavelength.htm
    Next stop is “infrared”, but humans can’t see that.
    So…if at all possible, avoid heavy use of red in GRFX or set design. You’ll be glad you did.
    Mark
  • Mike Procyk
    March 13, 2008 at 3:25 pm
    Got it. thanks.
  • Alan Okey
    March 13, 2008 at 6:41 pm
    [Mark Raudonis] “Red is the highest frequency color in the spectrum, and therefore is the hardest to reproduce.”
    Red is actually the lowest frequency in the visible spectrum, but has the longest wavelength.
  • Mark Raudonis
    March 13, 2008 at 10:04 pm
    Ok. So I’m not a scientist! 🙂 I stand corrected.
    Highest/lowest, it’s still the most troublesome to reproduce.
    Mark
