Activity › Forums › Apple Final Cut Pro Legacy › RED render bar to ORANGE please!
  • RED render bar to ORANGE please!
    Posted by Mark Jordan on June 2, 2011 at 7:01 pm
    Just switched to Final Cut Pro from express..however, ONLY getting the red render bar whenever i drop a new clip or effect in..I have been into playback settings and set RT both here and right of timeline to UNLIMITED…yet no change…making my editing ten times longer….is it a set up issue…based in UK, so PAL..any ideas welcome, thanks.
    Mark Jordan replied 15 years, 4 months ago 4 Members · 14 Replies
  • 14 Replies
  • Everest Mokaeff
    June 2, 2011 at 7:24 pm
    Please provide info on media files you try to edit and sequence settings.
    Free-lance fcp editor in Moscow
    http://www.mokaeff.com
  • Mark Jordan
    June 2, 2011 at 7:33 pm
    Thanks for quick response, however, could you be more specific for me and let me know exactly what to provide as there are 5 tabs in this section.
  • Chris Tompkins
    June 2, 2011 at 9:53 pm
    Your settings man.
    “CMD” 0 on your sequence.
    Codec?
    Format/codec of clips?
    Chris Tompkins
    Video Atlanta LLC
  • Mark Jordan
    June 3, 2011 at 12:11 pm
    Codec: Apple pro res 422 (hdv,xdcam hd etc)
    Frame size: 1024×576
    Compresor H264
    Note: clips I am using are quicktime from video library/stock sources if this helps?
  • Chris Tompkins
    June 3, 2011 at 12:40 pm
    That’s a odd size:
    Your compressor should be Apple Prores HQ on the sequence.
    Your clips should be converted to prores BEFORE you import into FCP. H.264 is NOT an editing codec.
    Chris Tompkins
    Video Atlanta LLC
  • Mark Jordan
    June 3, 2011 at 1:57 pm
    Great! Now I have the orange pre render view bar…but playback is now staggering..I’m now reconing there’s a memory issue going on!
  • David Roth weiss
    June 3, 2011 at 2:51 pm
    You clearly started using FCP without reading the manual Mark, and no matter how experienced you might be with FCE, you started your project incorrectly. First, study the following brief tutorial and memorize it: https://library.creativecow.net/articles/biscardi_walter/realtime_sequences.php. Then, use what you’ve learned every time you start a new project with FCP.
    BTW, what type of media drive are you using to feed video to FCP?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Mark Jordan
    June 3, 2011 at 3:50 pm
    David, you are correct LOL…I just assumed I could jump straight in and carry on with FCP from where I left off with FCE…I will have a look later at the link you have kindly sent me..at present I have not loaded any images from camera, just stock footage from internet library sites..also just moved the FCP prog from my main Imac drive to the external hard drive to see if that sped up the memory etc..once again, thanks for the help! 🙂
  • David Roth weiss
    June 3, 2011 at 4:09 pm
    Mark,
    You need to keep in mind that FCP does not automatically transcode video to useful codecs for you like FCE does. That’s left up to the editor. So, using video from the Web will likely bring with it issues. Just read the vast number of posts here from people using Canon DSLRs, FlipCams, GoPros, etc. to see that even experienced editors get caught by editing the bad stuff, only to find out later that they will need to reedit after transcoding to a proper realtime FCP codec.
    Also, you are right to move your media to an external drive (must be firewire or better BTW, no USB).
    David Roth Weiss
    Los Angeles
  • Mark Jordan
    June 3, 2011 at 5:56 pm
    David, just watched the link you sent, really helpful, confusing..but helpful LOL…codecs etc….I know, all starts to sound complicated…can’t i just go back to Imovie, LOL, life was much simpler then!!! :)))
