Activity Forums DaVinci Resolve RED R3D Clips don`t link to FCP XML timeline
  • RED R3D Clips don`t link to FCP XML timeline
    Posted by Christian Stoehr on October 24, 2012 at 4:04 am
    I just tried to import a XML timeline, and none of the R3D clips are linking, is there a special setting I am missing. I noticed that the Red files have a XYZ_001.r3d at the end, but the proxies have a XYZ_F.mov
    I did check the “ignore extension” box for the import, but since the “_001” is before the period, does that mess it up ?
    The “Force Conform with Clip in Media Pool” command is also shaded and its not letting me use it, even so the clip shows up fine in the media pool. Only difference is the last part of the name.
    Thanks for any help.
    Christian Stoehr replied 13 years, 10 months ago 3 Members · 5 Replies
  • Christian Stoehr
    October 24, 2012 at 3:20 pm
    So I`ve been able to get a bunch of clips to link, maybe 10% of the timeline, but I still have clips that won`t link, even so the footage got imported into the Media Pool.
    I am looking at the clip in the timeline with a film symbol on it and a crossed out circle on it (not just a Red X as described in the manual), and I have the matching clip selected in the Media Pool (that DaVinci imported) why won`t they connect, and why do I not get the “Force Conform with Clip in Media Pool” option (its greyed out) ?
  • Christian Stoehr
    October 24, 2012 at 6:56 pm
    So the solution was to change the RED Raw conform settings in the Project Setting window, and adjust the “timecode” to “Absolute”
  • Margus Voll
    October 24, 2012 at 7:55 pm
    glad that you solved it!
    Margus
    https://iconstudios.eu
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Andi Winter
    October 24, 2012 at 9:29 pm
    i guess it is greyed out because the track is locked. if you can’t unlock it, you
    are maybe in the master session.
  • Christian Stoehr
    October 24, 2012 at 9:56 pm
    Correct, forgot to mention that, the track was Locked. I should have figured that one out.
