Activity Forums Apple Final Cut Pro Legacy red proxy files
  • red proxy files
    Posted by Romy Marx on November 10, 2009 at 11:26 am
    Hi
    i copied my red folders on my mac
    then imported the proxy files to the FCP
    and dropped them on the timeline,
    the files doesn’t need to play realtime and can’t view them on the out monitor..
    same when i render them i can’t view them on the out monitor..
    my card is aja-kona HD
    does this happen with anyone of you?
    best regards
    Romy
    ROMY
    Dan Monro replied 16 years, 10 months ago 2 Members · 3 Replies
  • Dan Monro
    November 10, 2009 at 2:25 pm
    Romy,
    How did you import them? Drag and drop? Log & Transfer? And which files did you import? There are several sizes of quicktime proxies to work with – or did you bring in the R3D file?
    Also, what is your sequence size? And your audio video settings? Do they all match your source files? Do you have the REDCODE plug-in? Do you have the RED geometry activated in your Kona settings?
    Give us more info, maybe we can help,
    D
    Dan Monro
    FCP, Avid, AfterFX, Atlanta
    MacBook Pro 2.4 GHz Intel Core 2 Duo 2 GB ram
    Mac OS X 10.5.7
    GeForce 8600M GT Final Cut Pro 6.0.5 Quicktime 7.6
    – OR –
    2 x 3.2 Quad Xeon; 16 GB ram
    Mac OS X 10.5.8
    NVIDIA Quadro FX 5600 Final Cut Pro 7 Quicktime 7.6.4
  • Romy Marx
    November 10, 2009 at 2:39 pm
    >>>i imported them right click in bin then import proxy one<<< And which files did you import? There are several sizes of quicktime proxies to work with - or did you bring in the R3D file? >>>not r3d
    only i imported the proxy one<<< Also, what is your sequence size? >>i drag and drop it to seq<<< And your audio video settings? >>i want to know the true settings<< Do they all match your source files? >>my source file in REDCODE quicktime<< Do you have the REDCODE plug-in? >>YES<< Do you have the RED geometry activated in your Kona settings? >>i don’t know how can i activate it??<< >>>i did install the FCP installer from RED site<<< ROMY
  • Dan Monro
    November 10, 2009 at 4:02 pm
    First off, let me say I’ve got a total of one RED project under my belt and I had a lot of bumps. I’ll tell you how I did it and – hopefully – some more savvy folks will chime in.
    There is a file called “RED FCS Whitepaper” that downloads with the installer. it will lay out the Log & Transfer method for working with RED. Thats what I used, and it worked fine.
    There is also another workflow using Clipfinder, a free download, found here:
    https://www.daun.ch/software/
    Including a user manual.
    If you import the file, then you’re working at the size of the quicktime. By “proxy one” do you mean the one labled “_F”? I believe that will be at the size the RED was shot at – either 2k or 4k. Check the clip settings in your browser. Your sequence settings should match. But if you’re trying to play the native RECODE quicktime – even a proxy sizes- it may bog down.
    Look in your Kona preferences under the setup tab and make sure that your RED geometries are active.
    Take some time to read the workflows, and the forums on REDUSER.net
    https://reduser.net/forum/showthread.php?t=37314
    The time it takes to read up will more than make up for the time you spend floudering – I speak from experience.
    Hope this helps,
    D
    Dan Monro
    Mac OS X 10.5.7
    – OR –
    Mac OS X 10.5.8
