Activity Forums VEGAS Pro Red media and non-rendering clips and overlays
  • Red media and non-rendering clips and overlays
    Posted by Emmanuel Robles on January 15, 2010 at 7:36 am
    Hi, I’m having the following problems:
    #1 the usual “red” clips… still havent found a solution… not even rebooting, re-loading clips, etc…
    #2 i rendered a music video for a local band, and using clips from the exact same format (same camera, consecutive shots) some of them rendered perfectly and some didnt :S
    #3 is there a max size relation between over-layed images? if i try to render a logo (2000×750 transparent PNG) into a 720p footage, it renders perfectly, done it many times (with the exact same file), but the moment i try to render it over a 480p project, it does not render. when i place the image in the video track, it shows in the preview, but the moment i try to modify the pan/crop it dissapears with no way to bring it back.
    I´ve rendered way more complicated projects with no issues… so i dont think its a RAM or speed issue. I´m running Vegas Pro 9.0c 64bit on a core2duo 2.3GHz 4GB Windows7.
    Thnx in advance, best regards from Mexico!
    Philip Crangle replied 16 years, 8 months ago 2 Members · 1 Reply
  • Philip Crangle
    January 15, 2010 at 7:34 pm
    what codecs are you using?
