Activity Forums Adobe After Effects Red Giant Corner Pin; From Pins and To Pins
  • Red Giant Corner Pin; From Pins and To Pins
    Posted by Iris Moleman on July 29, 2014 at 4:31 pm
    Hi everyone,
    I’m trying to use the ‘From Pins’ setting in the RG Corner Pin Plugin, but it doesn’t seem to have any effect. When I set the ‘From Pins’ to a shape that matches the part of the image I want to use, the result is the same as when is don’t change the ‘From Pins’ settings.
    Am I doing something wrong?
    And another question about this…The User Guides says RG Corner Pin recognizes the Alpha Channel of the footage you add. But when I import a Photoshop file with a layer Mask, Corner Pin doesn’t use photoshop’s Mask.
    Screenshot from the user guide:
    Thanks in advance,
    Iris
    Iris Moleman replied 12 years ago 50,737 Members · 1 Reply
  • Iris Moleman
    August 22, 2014 at 8:50 am
    Does anyone have experience with the Red Giant Corner Pin Plug-in?
