Activity Forums Adobe Premiere Pro Red Frames from MXF clips
  • Red Frames from MXF clips
    Posted by Chris Walsh on December 19, 2014 at 11:38 pm
    I just had my first encounter with Premiere’s red frame error and it’s nearly enough to send me back to Final Cut 7. Seems to be a well documented issue for several versions of the PP:
    https://forums.adobe.com/thread/1620329
    Source clips were MXF from Canon C500, imported fine, edited okay until I started splitting and l-cutting, when suddenly red frames appeared in timeline thumbnails and/or exports.
    Clearing cache and restarting helped. Some exports were clean some were not. Some exports choked with a compile error. Frankly that is preferable since it saves me the time of having to QC every frame of the output.
    Am planning a complete hard drive wipe, new OS, new CC install to see if it helps but if my only solution is to transcode C500 footage before importing, then I’ll save the $50 a month and go back to FC7.
    Chris Walsh
    http://www.musicfog.com
    Silver Spring, MD
    Premiere Pro CC, FC7 & AVID
    Former Windows diehard and edit*or
    David Gaudio replied 11 years, 8 months ago 2 Members · 1 Reply
  • David Gaudio
    December 24, 2014 at 9:24 pm
    I had this issue last year with one of the CC versions, but it was fixed in whatever version came out first in 2015. It was a critical error for me as the show I was editing promos for was all MXF-based.
    No MXF issues with CC 2014 for me. I hope your problem is resolved quickly.
    BTW I didn’t have to wipe my hard drive at all; just the update from the beginning of this year did the trick.
