Activity › Forums › Avid Media Composer › RED footage to AVID then to RESOLVE with output of 4k
  • RED footage to AVID then to RESOLVE with output of 4k
    Posted by Ricky Milling on February 11, 2013 at 3:32 pm
    Hi, basically i have been asked to edit a 4k short film which they will want to have the final output at 4k. From what i understand i can link to the original material through AMA, then export a AFF for the grader in resolve.
    My question is that as AVID cannot create a sequence high than 1920×1080 im hoping that the AFF file will no limit the grader to 1920×1080 and instead be able to grade with the full 4k image and output from that?
    Ive done a round trip before, however the spec was only for 1080p.
    (NOTE IM GOING TO POST THIS IN THE RESOLVE FORUM ASWELL)
    Ricky Milling replied 13 years, 7 months ago 4 Members · 4 Replies
  • Shane Ross
    February 11, 2013 at 3:44 pm
    Avid tops out at 1920×1080. But the workflow is to export an AAF that is imported into Resolve that then telinks to the 4K originals.
    Shane
    Little Frog Post
  • Oliver Peters
    February 11, 2013 at 4:16 pm
    Check out the workflow I posted here:
    https://digitalfilms.wordpress.com/2013/01/12/offline-to-online-with-4k/
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Michael Phillips
    February 11, 2013 at 4:21 pm
    Just remember you will need the $1K version of Resolve to output greater than 4K.
    Michael
  • Ricky Milling
    February 11, 2013 at 4:34 pm
    Hey guys thats great news, i thought it would work that way, but wanted to make sure before i took on the project. That web guide is great and just what i was after. As for the Resolve part, thats someone elses job to grade and export 🙂
