Activity › Forums › Apple Final Cut Pro Legacy › RED Footage importing at odd resolutions
  • RED Footage importing at odd resolutions
    Posted by John Austin on July 12, 2009 at 3:53 pm
    When I import red footage into FCP via the log and transfer window it’s coming in at a frame size of 2048×1152. My final output will be to HD Cam which is 1920X1080. So I’ve used Red Rushes to convert the files to Apple ProRes HQ at 1920X1080, but the footage strobes a bit when I play it back. Does anyone know what I’m doing wrong?
    Steve Oakley replied 17 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • David Roth weiss
    July 12, 2009 at 6:09 pm
    [John Austin] “When I import red footage into FCP via the log and transfer window it’s coming in at a frame size of 2048×1152.”
    That’s not a strange size, that’s the standard widescreen size of a 2K frame at approximately 1.85 to 1 (which RED calls 2:1). Keep in mind, that’s a standard dimension for widescreen films — 2K images until recently have pretty much been the domain of feature films.
    When imported into FCP the video will be letterboxed in a standard 1920×1080 16:9 HD video frame, which is proper if you want to see the entire frame. If you want it to be full frame you will have to scale it to fill the frame horizontally, which will cut off the frame at both ends.
    Does this make sense?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • John Austin
    July 12, 2009 at 6:58 pm
    Yes it does, but my next question then is can this project be output directly to HDCam?
  • David Roth weiss
    July 12, 2009 at 7:10 pm
    [John Austin] “Yes it does, but my next question then is can this project be output directly to HDCam?”
    I’m not exactly sure what you’re asking John when you say “directly,” but I’ll wing it…
    With a suitable HD I/O card or device (Kona, BM, Matrox) and the proper Raid you can certainly output to HDCam. Depending on which card you have you can down-convert with the hardware to HDCam with some, while and with others you’ll have to create an HD timeline that scales with software inside FCP.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • John Austin
    July 12, 2009 at 7:52 pm
    yeah I just want to lay back to HD Cam from a time line thats 2048 X 1152. So would it be better to transcode the footage in Red Rushes to 1920X1080 and then edit in Final cut or does it matter?
  • Gary Adcock
    July 12, 2009 at 7:57 pm
    [John Austin] “yeah I just want to lay back to HD Cam from a time line thats 2048 X 1152.”
    max raster for SR tape is 2048×1080.
    I use a kona3 card to handle either conversion or crop from 2K masters during layoff. ( 2048×1080 or 1920×1080). That way the card is doing all of the work.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Check out
    https://www.aja.com/kiprotour/
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • John Austin
    July 12, 2009 at 8:13 pm
    I’m doing this on my mac pro lap top with Apple Pro Res 422HQ. Then We want to color correct in color and output to HD cam at 1080P. Does this sound like I’m on the right track?
  • Steve Oakley
    July 18, 2009 at 7:06 am
    an MXO2 would work nicely with the laptop….
    Steve Oakley
    DP • Editor • VFX Artist
    http://www.practicali.com
