Activity › Forums › Adobe Premiere Pro › Red flashes on export..
  • Red flashes on export..
    Posted by Brian Cooney on December 3, 2013 at 9:20 pm
    Is anyone encountering random red flashes upon export from PPro/Media encoder? This started happening just a couple days ago. They do not appear in playback in sequences but once exported, they start happening sparsely but randomly. no rhyme or reason. Exporting in 1080p h.264 mp4 codec. At first I was wondering if it had something to do with mattes and overlays in the timeline.. but not sure.. I’m going to try exporting from PPRO and bipassing media encoder and see what happens.
    Telly Award Winning Editor, Motion Gfx Artist, Colorist
    MotionFoundry, Inc. Post: Verizon, GM, Kohl’s, 3 Doors Down, L’Oreal, IKEA, Kelloggs, Toyota
    Peter Garaway replied 12 years, 9 months ago 3 Members · 9 Replies
  • 9 Replies
  • Brian Cooney
    December 3, 2013 at 9:35 pm
    ok.. I did a more extensive search on the Cow and a suggestion was to not use “render at maximum depth” option when encoding. that seems to have helped but not sure why it started happening all of a sudden… still thinking it’s because I have talent on layer 2 over a white matte on layer 1. Masking out portions of the talent over white and repositioning on screen… thinking this might be at the heart of the issue…
  • Peter Garaway
    December 4, 2013 at 4:07 am
    Hi Brian,
    We’ve done some work to address this in the next release. Please let me know if you still encounter the issue and we can work together to resolve your issue.
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • Brian Cooney
    December 4, 2013 at 1:47 pm
    Thanks Peter. When do you estimate that update be released?
  • David Mcgavran
    December 4, 2013 at 11:43 pm
    Hi Brian,
    We are taking this issue very very seriously. We have verified it and are doing final testing on a fix. The issue is related to ProRes import on 10.8 or 10.9 and a timeout issue. We should hopefully have a fix for you soon.
    Cheers
    Dave
    David McGavran, Adobe Systems Incorporated
    Senior Engineering Manager Adobe Premiere Pro
  • Brian Cooney
    December 5, 2013 at 3:29 pm
    Thanks David! Now that I have your ear….. Hey can you guys build in a feature where, like in AE, PPro will allow you to select multiple layered clips in a timeline and be able to select all of them and adjust position on all simultaneously without nesting? … or if not, make it so when in a nest or in the main sequence, like in AE, an adjustment layer can be assigned to specific clips in a layer? For example, If I create a nest or work in the main sequence, my adjustment layer effects everything. There are instances when I would like to omit one or two clips in a layer and adjust just the ones I want. – Thanks.
  • David Mcgavran
    December 5, 2013 at 4:40 pm
    That is a good request. Thanks!
    Dave
  • David Mcgavran
    December 12, 2013 at 5:44 pm
    This should be fixed in todays release!
    Cheers
    Dave
  • Brian Cooney
    December 12, 2013 at 7:35 pm
    Awesome! Anything other major changes in the update?
  • Peter Garaway
    December 12, 2013 at 7:54 pm
    Just a few things 😉
    See the list here:
    https://blogs.adobe.com/premierepro/
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
