Activity Forums Adobe Premiere Pro Red flashes in rendered mpg
  • Red flashes in rendered mpg
    Posted by Stevieb on January 17, 2007 at 5:16 pm
    CAn anyone help me understand why I get red flashes in certain sefgments of a rendered mpg
    Took 4.5 hours to render and the output is unusable
    Blast1 replied 19 years, 8 months ago 2 Members · 1 Reply
  • Blast1
    January 17, 2007 at 6:59 pm
    You ought to supply what version of the program you are working with, the workflow and settings you are using, some computer specs, the artifacts maybe caused by excessive motion, or noise, one thing to do is examime the source footage at the points the artifacts show up to see if there maybe some event that could be causing them.
