Activity Forums DaVinci Resolve RED file not rendering properly
  • RED file not rendering properly
    Posted by Chad Smith on May 2, 2012 at 9:38 pm
    Working with Resolve Lite 8.2.1 Grading a feature shot on RED ONE. For some reason on file will not render with proper in and out point and also is not taking the grade. I tried making a local version of the correction and tried to render just that clip but Resolve still wants to render the entire clip with no grade. Is there a way for me to get it to work? Hmmm.
    Chris Martin replied 14 years, 4 months ago 3 Members · 3 Replies
  • Brandon Thomas
    May 3, 2012 at 2:46 am
    Are you grading from the raw? What’s the name of the file?
  • Chad Smith
    May 3, 2012 at 3:05 pm
    Hi Brandon – Yes it is an R3D file that has variable speed adjustment. Perhaps that is the issue? File name is A087_C006_082420
    thanks
  • Chris Martin
    May 4, 2012 at 3:57 pm
    Yes probably a limitation of working with the live R3D. I know you can’t do render cache with R3D either. Try rendering it out at 1:1 speed. Then recreate speed effect back in your NLE. Better workflow anyway to color at 1:1 speed in Resolve anyway…
