Activity Forums Apple Final Cut Pro Legacy RED FCP log and transfer changes clip length
  • RED FCP log and transfer changes clip length
    Posted by Zac Rothman on February 13, 2009 at 6:31 am
    Hi there,
    Pulling my hair out. Trying to log and transfer R3D to Apple Pro Res 422 (HQ) in FCP.
    When clips are done, they are RADICALLY shorter (5 minute clips become 3:30, etc). I have checked the in/out clips (i tried NOT setting in and out points in log and transfer AND setting IN/OUT points at the very start and end of each clip). No matter what I do, the program seems to set its own in and out points.
    What can I do to fix this???
    Zac Rothman replied 17 years, 3 months ago 3 Members · 4 Replies
  • Russell Lasson
    February 18, 2009 at 4:26 pm
    Did you get it figured out? Have you tried deleting your preferences?
    -Russ
    Russell Lasson
    Universal Post
    Ridgeline Digital Cinema Mastering
    Salt Lake City, UT
  • Zac Rothman
    February 18, 2009 at 5:13 pm
    I did not figure it out. I just kept re-exporting the clips that were too short until they were the right length. In some cases I had to re-export 6 or 7 times. Red software/fcp plugin is simply not good enough by a long shot methinks.
  • Julie Snider
    May 11, 2009 at 8:44 am
    Hi there,
    I’m experiencing the same thing… did you ever find an answer to this problem?
    thanks!
    -julie.
    Julie
  • Zac Rothman
    May 11, 2009 at 5:32 pm
    No,
    I just kept re-exporting until it worked. It only took 2 or 3 times. About 60 percent worked the first time. RED post production just sucks. Good thing the footage looks so good.
