> red eye / light reflection eye / reduction in SV12
Posted by Thoreau Bakker on February 13, 2013 at 2:34 amHi All,
I have some interview footage with less than ideal lighting.
There is some kind of reflection in the girls’ eyes, like red eye but not red.
Anyone have any experience with this kind of footage in the past?
Any tips on a filter to reduce it?
Big thanks,
-t.Phil Seymour replied 13 years, 7 months ago 6 Members · 8 Replies -
Mike Kujbida
February 13, 2013 at 3:22 amA full res screen shot or a short piece of the video would help us to help you.
Thoreau Bakker
February 13, 2013 at 7:46 am -
Bob Peterson
February 13, 2013 at 4:50 pmYou can’t fix the video. It’s overexposed. There is nothing to recover. You can use a curve and pull down only the high whites (the upper right corner of the curve). You will have to put a second point on the curve to prevent dimming the mid range and low tones. That would make it grayer and less obvious.
You could replace the blown out pupil with, for example, a photoshop image, but that would require a LOT of keyframing to keep the still image in the right place on the video.
Thoreau Bakker
February 13, 2013 at 6:07 pmThanks for the reply Bob,
I had thought about key framing.. and as you say, that would be a mission and a half!
I will try your curve suggestion. Much appreciated!
-t.
Mark Barton
February 14, 2013 at 4:43 amYou could try a secondary color corrector and apply that to an oval mask, if you are using SVP 12. I tried it very quickly and it looked like it would need more work, but possibly less than all that keyframing. I was thinking if you could replace the bright highlight in the eyes with something more subdued it would be less distracting.
Frank Stevn
February 14, 2013 at 2:15 pmTry the chroma keyer by selecting the white color of the eyes. Place a dark color background (not black) under.
Thoreau Bakker
February 14, 2013 at 7:38 pmhey Guys,
I ended up just cutting out the 2 of 11 clips, as they needed the video really fast.
I appreciate all the great suggestions though and will go back and experiment with all of them. Good tools to have for future productions. Much appreciated!!
-t.
Phil Seymour
February 15, 2013 at 1:41 amNot of help, but have you thought of making vampire movies: 🙂
Windows 7 Pro64, i7 CPU, 16GB RAM, SSD boot drive, GTX 570 Graphics, Vegas Pro 12
