Activity Forums Adobe After Effects Red cross in window comp?
  • Red cross in window comp?
    Posted by Fariha Allana on March 2, 2009 at 11:09 pm
    I’m working on making a nice motion graphic in After effects cs4 and when i exported it as a movie i can see this red cross in the movie which is also on my AE workspace window? why is that?!?!
    Lukasz Wiecz replied 11 years, 5 months ago 3 Members · 6 Replies
  • Kevin Camp
    March 2, 2009 at 11:14 pm
    it usually means you have used a third-party effect that is unregistered.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Fariha Allana
    March 2, 2009 at 11:25 pm
    it’s a trial version for 14 days?
  • Fariha Allana
    March 2, 2009 at 11:26 pm
    But it’s a trial version that I did register my details. if i pay for it would it go?
  • Fariha Allana
    March 2, 2009 at 11:50 pm
    If I do purchase this plug in but need to reinstall my op system on my comp at a later stage will I loose the plug in as they sell you a downloaded version ONLY and not on a DVD?
    thanks
  • Kevin Camp
    March 3, 2009 at 3:27 pm
    yes, once you pay for it and register the plugin, the water mark will go away… usually they just email you a number and instructions on how to register it, but the process varies from company to company.
    if they send you an email, print it out and save it where you will be able to find it later (maybe in the box that ae came in). if you ever need to reinstall the plugin, you’ll most likely need to re-register it again so you’ll need that number again.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Lukasz Wiecz
    April 2, 2015 at 1:40 am
    Just to be fair this isn’t always if you have pirated software or expired trials. I had this problem when I was switching from personal to work username on new CC, if your trial is about to expire it will do this as well. I switched to my new account and problem was solved.
