Activity Forums Adobe After Effects RED color + RED gamma
  • RED color + RED gamma
    Posted by Paolo Martini on April 23, 2010 at 4:58 pm
    I’m going crazy. 😉
    Well, I opened my footage in REDCine, I have colorspace and gamma space
    set on REDSpace. Kelvin like 4 and something and tint -13.7.
    In the image window I have two buttons: M-D.
    I supposde D stands for default, that is the original RAW, which gives me colorspace: REDcolor and gamma:REDgamma.
    Importing in AE I know that it doesn’t recognize the metadata. Infact when setting the interpret footage it gives me tint 0 and kelvin 5600.
    Now.
    How am I supposed to work to go to DPX?
    Setting the values as the M settings or as the D setting?
    Please, any opionion would be appreciated.
    P.
    Todd Kopriva replied 16 years, 4 months ago 3 Members · 4 Replies
  • Tudor “ted” jelescu
    April 23, 2010 at 7:43 pm
    REDCine sees what settings you had in the camera, basically what you saw in your monitor at the shoot – however, AE sees the raw data without any interpretation. So, if you want to see the same thing as when you shot the footage, use the M settings- if you want to color grade from scratch, use the footage as it comes in AE. ( of course you have to set AE to interpret the RED color space the right way, but I think you’ve read the info from the RED site)
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Paolo Martini
    April 24, 2010 at 12:53 am
    Thanks Tudor.
    I have another question.
    Besides the fact that from RedCine to AE, same color space and gamma I can see a slightly difference in colors, I need some info in the export linear DPX stuff.
    I would really need to know if it’s essential to interpret the footage as gamma linear, and then work in a linear space (so all the other footage).
    I am not so experienced in this procedure, but it gave be some very good result when comparing RED Dpx (gamma linear) exported from RedCine to the ones with some small VFX (interpreted also as gamma linear) exported (with gamma 2.2) from AE.
    what can you say about that?
    thanks.
    p.
    April 24, 2010 at 1:23 pm
    Work in 32 bit, do not set gamma to linear, make sure your QuickTime is set to display a 2.2 gamma (read below).
    “Dynamic Link allows content from one application to be shared with another without exporting intermediate files or even copying projects. Edits and other changes are automatically updated across applications.
    You can use a Premiere Pro sequence as footage in After Effects. In After Effects, choose the File > Dynamic Link menu command. In After Effects, you’ll get a single linked clip that represents the duration of your Premiere sequence; you can still go back to Premiere Pro to refine your edit. Changes will be updated in After Effects. Premiere Pro sends a complete frame with all effects, transitions, etc. Nothing is lost.
    Another advantage to using a Dynamic Link from Premiere Pro to After Effects is that you can then use After Effects’s render queue to export to a wide variety of image sequences and formats: 4K 2K, extended color range DPX, 16 – bit Tiff, TGA, and so on. Our initial tests have shown this option to be faster and more robust than using Adobe Media Encoder. This workflow is pretty straightforward — complete your edit in Premiere, then as a last step, import the sequence into After Effects, add to render queue, and export.” (from the first link below)
    Here’s a few useful links:
    https://www.studiodaily.com/studiomonthly/currentissue/10320.html
    https://blogs.adobe.com/premiereprotraining/Red_Plugin_Workflow_112608.pdf
    https://www.adobe.com/devnet/aftereffects/articles/color_management_workflow.html
    https://www.vfxtalk.com/forum/red-one-film-luts-color-space-workflow-t15369.html
    https://blogs.adobe.com/toddkopriva/2009/05/after_effects_902_update_red_r.html
    https://www.red.com/faq/category/workflow/
    https://vimeo.com/3700619
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
  • Todd Kopriva
    April 24, 2010 at 11:47 pm
    As the author of one of those pages that Tudor pointed to, I’ll recommend that you read the “updates for RED (R3D) footage” section of this page. It tells you what you must and mustn’t do to keep your colors straight. (Tudor mentioned some of them.)
    I wrote that section together with the relevant engineers from RED and the After Effects team, so I’m certain that it’s good advice.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
