Activity › Forums › Adobe Premiere Pro › Red clips to 1080 sequence and export for DVD
  • Red clips to 1080 sequence and export for DVD
    Posted by Paco Bech on June 23, 2012 at 5:20 pm
    Hello, I am editing Red clips in a 1080 sequence. Final destination is DVD
    Do I have to render the work area? now I have the red line and working with previews. am I downscaling doing this?
    To create DVD with maximun possible quality. Do I have to export in some particular format, g to encode and then encore? like you do in FC with compressor and DVDSP. or I just have to export a DVD MPEG-2 file?
    Best regards
    Ann Bens replied 14 years, 3 months ago 3 Members · 3 Replies
  • Chris Tompkins
    June 23, 2012 at 5:57 pm
    Choose the Mpeg2 DVD preset when exporting.
    Adjust data rate to maximize quality to space ratio.
    When that is done, import the 2 files into Encore, set first play, test and burn.
    Chris Tompkins
    Video Atlanta LLC
  • Paco Bech
    June 24, 2012 at 8:07 am
    The edit is only two minutes long,
    I have maximun, target and minimun bit rates , how should I set this?
    best regards
  • Ann Bens
    June 25, 2012 at 10:17 pm
    Try the default setting first.
    If that does not give a good result tweak the target and max.
    Dont forget to set Use Max Render Quality and do not use Preview Files.
    You do not need to render before export.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
