Activity › Forums › Apple Final Cut Pro Legacy › Red Cam IOHD FINALCUT TIMECODE
Posted by Nicholas Verlaine on April 16, 2009 at 4:30 pmI am a video assist in toronto. with the red cam there is no timecode display when the dp is using the evf and the ac is using the onboard monitor.
my iohd sees the red timecode through the sdi out. final cut does not register the timecode when capturing.
is there a way to rectify this?
i often need a timecode source to scroll to an accurate point on the capture for playback.
nickJeremy Garchow replied 17 years, 4 months ago 4 Members · 11 Replies -
Russell Lasson
April 16, 2009 at 5:16 pmFinal Cut only supports timecode capture when there is deck control enabled. AJA tool should work though.
-Russ
Russell Lasson
Universal Post
Ridgeline Digital Cinema Mastering
Salt Lake City, UT -
Nicholas Verlaine
April 16, 2009 at 7:30 pmexcept vtr exchange jumps and skips on playback, and clips from it do not import into fcp properly. Its nearly the answer. hopefully FCS 3.0 will be the answer!
Jeremy Garchow
April 16, 2009 at 8:55 pmThe you have something setup incorrectly. I use VTR Exchange all the time to capture ProRes or HQ material that is used as master footage for multiple cameras (never done it from a red, but if it’s 720p video, the ioHD will capture it). Check the audio and video settings of VTR Exchange.
Jeremy
Gary Adcock
April 16, 2009 at 9:29 pm[nicholas verlaine] “cept vtr exchange jumps and skips on playback, and clips from it do not import into fcp properly. Its nearly the answer. hopefully FCS 3.0 will be the answer!”
Operator error.
RED VO does not support anything other than 720p59.94 or 720p5.
stop trying to capture at 24p and it should work just fine.
gary adcock
Studio37
HD & Film Consultation
Post and Production WorkflowsInside look at the IoHD
https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php -
Nicholas Verlaine
April 17, 2009 at 6:42 pmnope, still the odd skip.
have tried every setting.
thanks anyway! -
Jeremy Garchow
April 17, 2009 at 6:48 pmWhat codec/setting are you trying to capture to and what disk drive do you have?
Nicholas Verlaine
April 17, 2009 at 6:54 pm720p 59.94 onto a lacie dt 1.5tb or a caldigit s2vr into prores 422
Jeremy Garchow
April 17, 2009 at 7:21 pmAnd are those fw800 drives? Do you have a fw800 Express 34 card?
