RED 5 for Media Composer 6 Timeline? Also BCC8 updates?
Mike Meyerson replied 14 years, 6 months ago 6 Members · 21 Replies
Peter Mcauley
January 31, 2012 at 10:21 pmAlso, and just for the sake of clarity, do you think you might be able to send us some images that show us exactly what the problem looks like on your system?
Peter.
Wojciech Baredziak
January 31, 2012 at 10:40 pmPreferences/Settings were the first place when I looked, but … I’m at the front of my system and:
-composition window – preview quality: high
-composition window – preview resolution: full
– render in draft mode – uncheckedTransition quality is poor … soft images, looks like in draft mode – sorry.
I try preset: Library >Transitions/DVE Transitions/Wipes/QuadBar DVEIt is interesting, that not all presets are poor ! Some looks perfect.
I use only presets for my tests. -
Wojciech Baredziak
January 31, 2012 at 11:06 pm -
Boris Yamnitsky
February 1, 2012 at 2:32 pmWe posted AvidFX 6.03 for MC6, 64 bit, windows platform. All windows AvidFX users are encouraged to download a free update:
https://www.borisfx.com/updates/#null
Boris Yamnitsky
BorisFX -
Peter Mcauley
February 1, 2012 at 2:43 pmOkay – I think I have figured it out.
• Load the preset that you were using (QuadBar DVE Wipe)
• Select Track 1
• Go to the Composite Tab in the Controls Window
• Scroll down and observe that there is a parameter labelled Horizontal
• Remove any keyframes for this parameter and set the value to 0 (or you can achieve the same thing by setting the keyframe interpolation for this parameter to Constant and setting the value to 0)Do the same thing for the other track.
Please let me know if this produces the result that you have in mind.
Cheers,
Peter.
Wojciech Baredziak
February 1, 2012 at 2:44 pmThe fastest reaction I’ve ever seen – update without 12 hours 😉
Just downloaded … -
Wojciech Baredziak
February 1, 2012 at 2:47 pmThank you Peter – I’ll try it with 6.0.3 update and report here …
Wojciech Baredziak
February 1, 2012 at 4:35 pmA BIG RESPECT for you Peter !
I’m not new in Red, but looks like I was blind for the last two-three days.
Problem solved and all works fine, now.
Thank you for your assistance and time.All the best.
Peter Mcauley
February 1, 2012 at 4:41 pmDelighted to hear that helped solve the problem – thanks for letting me know that you’re all set – and for the kudos.
Cheers,
Peter.
Wojciech Baredziak
February 2, 2012 at 9:48 amI have tested more presets. It looks like new version has some problem to open correctly “older” presets. Very often horizontal and/or vertical parameter is set to 15 – 16 value.
