RED 120fps to 24fps slow-mo…then to Avid
Later today I will be receiving some 120fps RED footage that we want turned into slow motion. I’m working on FCP but it will then go to an Avid system, more on that later.
I just wanted to run my workflow with the experts since this is my first time actually working with new RED footage, let alone turning it to slow-mo. I’ve tested with pre-existing RED footage so I have some idea of how it works, but still pretty new to it. The project is going out to broadcast 1080p.
Here’s what I’m thinking of doing, please correct as you see fit:
1) Using FCP, I’ll Log & Transfer the RED footage into ProRes 422. Do I really need 4444 or 422 HQ? Should I use REDAlert (which I am HIGHLY inexperienced with)? With the RED footage I tested, it shows up overly green so I figured Log and Transfer in FCP would be easier since I am more familiar with it.
2) With the QT that are created, I’ll bring those into Cinema Tools and conform them to 23.98 (I’m new to Cinema Tools but I have tested some other clips. Unless I’m missing something, seems that it is destructive to the original clip as in it conformed my 60fps footage to 30fps and I found no way to turn it back. Guess I just have to duplicate the footage just in case.
3) Edit away using the newly conformed 23.98 clips.
I’m thinking that converting 120fps to 24fps should be slow enough. At first I was thinking of using Twixtor but it may be unnecessary. However, if I did want to slow the 23.98 footage even more, what would be the best way to do so? Or is that pretty much the end of the line?
Now the Avid part. I’m leaving for vacation in a week so I won’t be finalizing and outputting the project…unless I get everything done in a week which is ideal but unlikely with these clients.
I’ve spoken with the Avid editor and I quote,
“The most workable solution would be for you to do your work as you would normally and when the time comes for us to take over have you sent a QT file with the timecode burned in. We would then use that as a reference for recreating the sequence on our end with the raw RED footage and moving forward from there.”
Is this really the most efficient way? For them to more or less cut it again from scratch? An EDL would help I suppose but is there anything else I should be aware of? Given my intended workflow, is there anything I should keep in mind?
Any insight would be greatly appreciated. Also, just wanted to say thanks to everybody who helps out here. I’m relatively inexperienced and you guys have helped me out numerous times!
