Rectangular Pixel Setting: Where? (also tips for higher quality?)
The bottom line: Where can I find the setting — in Final Cut, in Compressor, or in DVD Studio Pro — to use rectangular instead of square pixels on export (or burn or wherever)?
The story: I’m trying to burn a DVD for a friend of our kids’ jazz concert. It looks great on computer. Once in DVD Studio Pro’s simulate function, though, all the the performers look slightly stretched. They look that way on TV, too. My understanding is that this is due to the difference in computer and TV pixel shapes and that there is a setting somewhere to address it.
Below are my settings in Compressor, if that helps. And, if anyone can recommend settings for higher quality (I’m getting some stepping which looks lousy on big TVs), I would love to hear them.
Thanks much,
Gary
Name: MPEG-2 7.5 Mbps 2-pass
Description:
File Extension: m2v
Estimated size: 2.88 GB/hour of source
Type: MPEG-2 video elementary stream
Usage:SD DVD
Video Encoder
Format: M2V
Width and Height: Automatic
Pixel aspect ratio: Default
Crop: None
Padding: None
Frame rate: (100% of source)
Frame Controls: Automatically selected: Off
Start timecode from source
Aspect ratio: Automatic
Selected 16:9
Field dominance: Automatic
Average bit rate: 6.4 (Mbps)
2 Pass VBR enabled
Maximum bit rate: 7.5 (Mbps)
High quality
Best motion estimation
Closed GOP Size: 1/2 second, Structure: IBBP
DVD Studio Pro meta-data enabled
