Activity Forums Adobe After Effects Recreating the matrix scene with rushing rows of guns in AE 7
  • Mylenium
    December 22, 2006 at 8:03 pm
    Mmh, if you have shots of the shaleves you can simply mape them onto 3D layers in a sub-comp to form a box, then drag that composition in your main comp, enable “collapse transformations” and animate it with 3D properties intact. Otherwise I think that is more of a job for a 3D program – doesn’t need to be extrmely detailed, just some weapon dummys rushing in with lots of motion blur. The row closest to the camera most likely could be shot for real using toy/ replica guns.
    Mylenium
    [Pour Myl
  • Mike Clasby
    December 22, 2006 at 8:15 pm
    You might want to click on Aharon’s Camo hat and scroll down to:
    Unlocking the Secrets of Effectively Using Z-Scale
    There is a comp named “Building Expand” that use Z-Scale to accordion out a cityscape.
  • Fabiano Chaves
    December 22, 2006 at 9:20 pm
    thanks alot!!! Really apreciate your help!!
