Activity › Forums › Adobe After Effects › Recreating an animation – bending a flat plane in 3D space
  • Recreating an animation – bending a flat plane in 3D space
    Posted by Dustin Parsons on March 26, 2012 at 11:11 pm
    I’m trying to recreate the simple animation found here, but I can’t seem to get mine to look as good. The main problem I’m having is getting the outer skin layer to appear 3D because my 2D version just isn’t cutting it.
    Is there a free plugin similar to ZaxWerks 3D Warps that can do this or another plugin that works better than the ZaxWerks one?
    Tudor “ted” jelescu replied 14 years, 6 months ago 3 Members · 5 Replies
  • Tudor “ted” jelescu
    March 27, 2012 at 7:55 am
    For 3d distortion you can use FreeForm – comes bundled with AE.
    Also, for 2d distortion, Mesh Warp is great.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Erik Waluska
    March 27, 2012 at 4:08 pm
    A really easy way would be to use 3D stroke (or just plain stroke)and the bevel layer style. Here is a quick example project for you…
    3908_wrinkles.aep.zip
  • Dustin Parsons
    March 27, 2012 at 5:12 pm
    I found FreeForm in AE. Looks like it does what I was hoping it could but it is difficult to work with. Thanks for the suggestion!
  • Dustin Parsons
    March 27, 2012 at 6:03 pm
    Thanks Erik. I don’t have 3D stroke so I’ll give the regular stoke a shot.
    March 27, 2012 at 8:48 pm
    Mettle has released Free Form 2 – faster and more powerful than the bundled version, and if you have a bit more to add to the budget you can jump up to FreeForm Pro, a lot faster and even more powerful. That will enable you to animate and add reflection, texture and displacement.
    Tudor “Ted” Jelescu
    Senior VFX Artist
