Activity › Forums › Adobe After Effects › Recreate crude circle grid animation
  • Recreate crude circle grid animation
    Posted by Al Mach on January 31, 2018 at 7:42 pm
    I want to recreate the circle grid animation in the beginning of this video. I haven’t been able to find any tutorials online that demonstrates how this can be done. It appears pretty simple. Can anyone help me get this started? Thanks in advance.
    https://www.youtube.com/watch?v=P2AZH4FeGsc
    Al Mach replied 8 years, 8 months ago 3 Members · 4 Replies
  • Eric Santiago
    January 31, 2018 at 8:45 pm
    Spherize a solid with Grid applied to it.
  • Eric Santiago
    January 31, 2018 at 8:56 pm
    Sorry I was a litte to quick on reply.
    You can do this using an Adjustment Layer with Spherize applied at center.
    Under the Adjustment Layer use a super wide Solid (20480×2048) and apply a Grid to it using Width Slider.
    Animated the position from left to right (whatever floats your boat).
    PreComp that and apply a Track Matte using a Spherical Mask.
    Use that Comp and apply on any layer of your choosing.
    Does it look great…not really.
    I would have done this in Maya.
    Im just lazy that way 😉
  • Richard Garabedain
    January 31, 2018 at 9:29 pm
    grid plus cc sphereize
  • Al Mach
    January 31, 2018 at 10:00 pm
    Thanks for this. I’ve never used a width slider before so not sure how to do that. But I did everything else, and the grid showed up. The problems I have are:
    1) The lines on the y axis show a fake perspective because of the sphere effect. I want the vertical lines to be the same width throughout.
    2) Don’t know how to skew the grid so it’s more oval, and not a perfect circle.
    I thought this would be easier than it actually is. Is it possible to do what I’m describing without frame-by-frame animation?
