Activity Forums Canon Cameras Recovering a C100 spanned clip
  • Recovering a C100 spanned clip
    Posted by Chris Sinclair on September 4, 2013 at 8:10 pm
    I’m in trouble. I recorded an interview that spans both A and B cards on a C100. Trouble is, the B card with the second half of the interview clip has been formatted several times by accident (Quick initialize mode on the C100). When using the Data Import Utility with the A card, at the end of the ingestion process it says “There is a video relayed between two clips. Insert the SD Memory Card in which the paired relay clip is saved.” Well since I don’t have that second card, is there any way I can use software to recover the existing portion of that interview file, either through a capture stream, or other recovery software? I’ve tried using https://www.datarescue.com ‘s PhotoRescue software, to no avail. Or am I SOL? I’ve already checked the Pixela Corp (makers of the Data Import Utility software) and no dice.
    Thanks for any tips.
    Chris.
    Chris Sinclair replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
