Activity Forums Panasonic Cameras Recording Live from HVX to FCP
  • Recording Live from HVX to FCP
    Posted by Dana Hopper on April 18, 2008 at 10:26 pm
    I’ve connected the HVX to a Macbook Pro by the 1394 cable. My FCP scratch disk is an external hard drive. I’d like to capture live video from the HVX to the hard drive. I used free run to generate time code but when I go into Log and Capture, hit capture now, it tells me I need to be in VTR mode to record.
    Everything I read tells me this can be done. So either my set up is wrong with the HVX, FCP, or both.
    Any suggestions?
    Many thanks,
    Dana
    Michael Sacci replied 18 years, 5 months ago 5 Members · 4 Replies
  • Noah Kadner
    April 18, 2008 at 11:16 pm
    Set capture device to non-controllable.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the Sony EX1 Guidebook
    https://www.callboxlive.com
  • Jose Alvarez
    April 19, 2008 at 4:32 pm
    Hello
    I am trying to do the same thing, but recording live into a deck (sony HD700 Walkman).
    Maybe you need to download first into your local drive and then make a copy into
    the external drive. I get drop frames when working directly into an external HD>
    good luck
  • Richard Harrington
    April 20, 2008 at 12:31 am
    Dropped frames means drie not fast enough or data througphut
    Make sure you use a separate bus (ie a card) for second set of ports… can’t ingest and write at same time (in out over same bus)
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Michael Sacci
    April 20, 2008 at 1:52 am
    [Jose Alvarez] “sony HD700 Walkman”
    This is a HDV deck so unless you have the camera and the deck set to DV25 there is no way of getting it to record a DVCProHD signal.
