Activity › Forums › AJA Video Systems › Recording AND transferring data AT THE SAME TIME!
  • Recording AND transferring data AT THE SAME TIME!
    Posted by Marty Hankins on April 8, 2012 at 5:12 am
    Noticed something usually but very usefully the other day.
    The setup – KiPro (HD 1080 record) KiPro Mini (SD 576 backup record) Units are networked together as a gang record.
    At a music festival recording with plenty of Hard Drives for the Main KiPro but the KiPro Mini (backup record)has only 1x64Gb card so I need to transfer data from the Mini often. The units are gang recording. So I noticed that when I change the Mini to transfer mode (Data-LAN) and start the transfer of data then also started the gang record the Main KiPro goes into record , the mini doesn’t show up as recording yet the available storage is decreasing and when stopped there is a recorded file!!! I have not tested this fully with HD recording and suspect that there may be bandwidth issues. Useful “feature”! I am sure the following posts will be “it shouldn’t be done” but hey good to know when your out of space and can’t delete the files on the current drive.
    Marty Hankins replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
