Activity › Forums › Panasonic Cameras › recording 16:9 and 4:3 on same field tape
  • Noah Kadner
    October 28, 2005 at 4:57 pm
    Yes no problem at all. It will present something of a headache in post though- you’ll need to be careful in capturing one mode or the other with the proper capture settings. Mixing them in the same sequence will also be problematic unless you’re going for a certain artistic effect.
    Noah
  • Frank Cervarich
    October 28, 2005 at 5:19 pm
    Noah –
    I am planning on using them in the same timeline. What sort of problems are you referring to? I’m all ears.
    Frank
  • Noah Kadner
    October 28, 2005 at 10:04 pm
    one will have to be rendered to match the sequence. Either the 16:9 to match a 4:3 sequence or vice versa. That would require a lot of extra render time or you could simply render entire tapes at once overnight I suppose. Personally I would never want to mix these formats. If I wanted an aesthetic effect, I’d shoot all 16:9 and then window box shots I wanted to look 4:3.
    Noah
