Activity Forums Audio Recorder for Rode Lavalliers
  • Recorder for Rode Lavalliers
    Posted by Rocco Rocco on June 5, 2013 at 1:51 am
    Forgive the newbie question.
    I have a Rode Lavalier Microphone and I’m a little confused as to which recorder I can use. In my mind this combination works:
    Lavs> Micon 5 XLR> Tascam DR100
    Is this correct? Is there a reason this won’t work, such as phantom power issues. And what about the Micon 2 1/4″ adaptor? Is it possible to just plug this into teh Tascam?
    Ty Ford replied 13 years, 3 months ago 2 Members · 3 Replies
  • Ty Ford
    June 5, 2013 at 2:58 am
    Hello Paul and welcome to the Cow Audio Forum.
    “The MiCon-5 is designed to connect to a standard 3 pin XLR, with P48 phantom power.”
    “When using a condenser mic that requires phantom power, set the +48V switch to ON.”
    The above sentences are from online info about the mic and recorder. Any questions?
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Rocco Rocco
    June 5, 2013 at 4:38 am
    Thanks for the reply. That’s what I thought, but for what ever reason my set up isn’t working. Not sure if its the Digital recorder, the Micon or the lavs.
  • Ty Ford
    June 5, 2013 at 12:12 pm
    Paul,
    Use the process of elimination to get to where you want to be. Try another condenser mic that requires 48 V DC Phantom Power.
    Read the manual to see if there’s a switch in the wrong position.
    Regards,
    Ty Ford
