Activity Forums VEGAS Pro Recorded voice crackles and rings
  • Recorded voice crackles and rings
    Posted by Stella Bruggen on March 26, 2016 at 1:45 pm
    Hi everyone!
    I’m having a problem with my recording. I’m trying to record a song – a capella, just me times three – but the mic (which is supposed to be decent, though a little old) will only register sound if I put it to +20.00DB amplification while recording.
    So I do that, I record it, everything’s fine, though the peaks never reach more than halfway but okay. So then I put a reverb-effect on it. Sounds great through my headphones, but when I play it through the speakers, it crackles and rings. Now the problem is: I don’t know what this phenomenon is called, so I can’t fix it . I can’t even look for help online.
    I’ve tried overdrive and over-steered, literal translations (I’m Dutch) but to no avail. I’m thinking it’s something I do wrong while editing, cause it’s not like the mic is recording it that loudly…
    Thanks in advance =)
    Stella
    Wayne Waag replied 10 years, 5 months ago 2 Members · 1 Reply
  • Wayne Waag
    March 26, 2016 at 10:06 pm
    Stella,
    It’s most likely not in your editing, it’s in your recording. If you have to add +20db to hear anything, you definitely have a problem. But, you need to provide more information. What type of mic are you using? What are you using to record? Sounds like your PC? Audio recorder? If it’s a PC, what audio card are you using? What recording software are you using? Before anyone can help, you will need to provide detailed information.
    wwaag
