Activity Forums Adobe Premiere Pro Record video and audio from seperate sources
  • Record video and audio from seperate sources
    Posted by Elijah Lucian on September 3, 2009 at 5:06 am
    ok so i have CS3 and this is really bothering me!
    i need to record audio from my MOTU 896mk3
    and my video from my sony camcorder…
    but its not working ive tried everything. i’ve been googling for DAYS!
    any advice from you guys? am i just using the wrong software for what i want?
    Elijah Lucian replied 16 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Brian Louis
    September 4, 2009 at 1:35 am
    You are not going to get much help unless you tell people what kind of system you are using and its specs
  • Elijah Lucian
    September 4, 2009 at 1:45 am
    windows vista ultimate 32bit
    3 gb ram
    quad core @ 2.4ghz ea
    hp motherboard
    Video – geforce 8800GT
    audio – motu 896mk3
    camcorder – sony dcr-hc26 handycam
    is that enough?
  • Brian Louis
    September 4, 2009 at 9:19 am
    How many audio tracks are you trying to record? Are you trying to record the video and sound live? Have you checked the audio setups in Preferences? particularly the ASIO settings
  • Elijah Lucian
    September 4, 2009 at 2:22 pm
    im trying to record 2 tracks (analog 7/8) and yes i have checked the asio, but there are no options to select the default input with MOTU ASIO
    when i use the default asio driver, it disregards anything i put in, leaving it recording on the default speaker (camcorder speaker) has anybody tried recording from a different mic with a firewire camera?
  • Brian Louis
    September 4, 2009 at 10:55 pm
    [elijah lucian] “the default input with MOTU ASIO”
    I’m talking about the ASIO selections in Ppro
  • Brent Oetken
    November 15, 2009 at 6:22 pm
    I have the same issue. I’m surprised that Premiere doesn’t allow you to select separate input sources like Vegas does. The only work around I can find is to manually enable/disable my audio recording devices on the PC.
    Still searching for a good solution to record video from one source (DV; firewire) and audio from another (m-audio; USB).
  • Elijah Lucian
    November 16, 2009 at 12:08 am
    yeah i think the reason nobody else understands is because they’re not familiar with what ‘motu’ or ‘m-audio’ is…
    brian louis: i know the settings you’re talking about. what im telling you is that when you select a firewire video input the audio is greyed out. it will not let you select a seperate source. my question is regarding a workaround. so far the best ive found is reducing my video to USB and using sony vegas. it seems to be a superior program anyways.
