Activity › Forums › Adobe Premiere Pro › Record HDSDI output
Record HDSDI output
Posted by Paul Rozon on August 5, 2010 at 1:27 pmI am looking for suggestions for an economical way to record the line cut of a show (HDSDI out of a panasonic switcher)for the purpose of editing it later. I will be editing on Premiere Pro PC.
My first thought is record to Laptop but am not sure what specs and hardware would be required to make this a reliable solution.
Any suggestions would be appreciated. Thanks
Paul
Vince Becquiot replied 16 years, 1 month ago 3 Members · 14 Replies -
Vince Becquiot
August 5, 2010 at 4:05 pmHi Paul,
HD SDI is still fairly expensive no matter where you look. The most reliable way would be using a digital or tape based deck. I would look around for a rental house and see what they are offering. For tape based recording, we like DVCPro HD. You could certainly look at Blackmagic or AJA and use any of their HDSDI cards for recording, but I wouldn’t rely on that as a single recorder, well I would never rely on a single recorder period.
On the laptop side, not much in the HDSDI area. If you could get a hold of a MacBookPro, there is this great AJA product.
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Paul Rozon
August 6, 2010 at 2:27 pmI do have a a brand new macbook pro. Have you used this product first hand? Would a stock macbook pro with firewire be able to keep a sustained HD stream (2 hours plus) combined with the io pro?
Vince Becquiot
August 6, 2010 at 5:06 pmIt will, but not to uncompressed. It captures to ProRes, which may not be the solution you’re after since you are using Premiere. I used it a couple of times with FCP. I still would want to have some redundancy.
We are actually looking at buying one of these, that may be what you are after.
Vince Becquiot
Kaptis Studios
Cravin Moorehead
August 7, 2010 at 1:00 am -
Paul Rozon
August 7, 2010 at 2:00 pmActually I have posted the same question on the HPX camera forum as well and have been pointed in the direction of the Ki Pro. Also had some discussions on the Ki Pro forum as well.
I am pretty muched convinced it is the unit for me but I am looking for anyone to confirm that the prores codec for PC works well with CS4 Premier Pro. I will search the archives to see what users are saying.
Thanks for the info.
Vince Becquiot
August 7, 2010 at 2:13 pmThe Ki Pro is an excellent product but is really aimed at Fcp. I would be very reluctant to edit Prores on a regular basis in Premiere.
Paul Rozon
August 7, 2010 at 3:08 pmI am currently looking through the archives to see if anyone is having problems with prores on CS4 PC. I havent found anything yet but am still looking. Maybe I will pose the question in a new thread.
Do you have first hand experiences with prores on PC?
Vince Becquiot
August 7, 2010 at 4:39 pmI have edited using Prores(on a 10 minutes long project), and CS4 did crash a few times. I can’t say that it was caused by Prores with certainty, but I rarely saw any crashes in the 2 years we used CS4.
The performance wasn’t that great either, which is why I would hesitate investing in expensive hardware that provides a format that really hasn’t proven to be reliable in Premiere.
The reason you won’t find any posts on the subject is that most people don’t even know they can download a Prores codec for Windows.
Also keep in mind that you are depending on Apple for updates. If Adobe was to provide an update on their side that broke the functionality of the format, I imagine Apple wouldn’t rush in to fix it.
Vince Becquiot
Kaptis Studios
Paul Rozon
August 7, 2010 at 7:13 pmNo reply on the new thread with regards to prores on PC. As you say, must not be a lot of people using it. I am certainly not interested in being the one to break new ground with untried codec.
sure is a sweet looking machine. I liked the idea of being able to record an SD downconvert simultaneously for quick client dub and backup.
Is there a PC equivelant that you are aware of. something with the recorder built in?
I will continue my research.
Vince Becquiot
August 7, 2010 at 7:20 pmHi Paul,
I still am not clear as to whether you are looking for an uncompressed capture solution, or simply a way to get from HDSDI to the MBP?
For the second option there are tons of converters that will do that, and you could easily record with Adobe OnLocation through firewire
Vince Becquiot
Kaptis Studios
