Activity Forums Panasonic Cameras record backup to tape
  • record backup to tape
    Posted by Supervideo on May 31, 2007 at 6:30 am
    could someone please tell me if with the Panasonic hvx200 ,I could record HD to a FS 100 Hard drive …and make a backup to tape ( in standard DV ) at the same time ….also From what ive read it has 4 audio tracks , Could I record to all 4 at the same time maybe 2 with the XLR and the other 2 with the line in Jacks
    thanks for any info
    Rainer Wirth replied 19 years, 3 months ago 3 Members · 2 Replies
  • Lance The tech
    May 31, 2007 at 9:16 am
    While you are recording HD in any way (output through Firewire or on P2 card)the DV section is totally disabled. In fact you cannot even insert or take out a tape as there is no power going to the mechanism.
    Audio in HD is channeled according to the inputs you select. If 1 and 2 are external XLR’s then 3 & 4 will be the internal mic. You cannot record from both the XLR’s and the RCA’s at the same time.
  • Rainer Wirth
    May 31, 2007 at 2:17 pm
    I think it is not possible too.
    Rainer
